[postgis-devel] ST_AsMVTGeom() feature size limit
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue May 18 16:59:16 PDT 2021
Hello,
I had a similar complaint previously and the recommendation I got was that
if I want to show more finely grained data on the vector tiles, I should be
raising the `extent` value.
There is a Simplify call at the end of ST_AsMVT that uses the wrong
epsilon. It should be 0 instead of 0.5px. Please check this fix:
https://github.com/postgis/postgis/pull/463/files - I'd be happy if it gets
committed. :)
On Wed, May 19, 2021 at 1:31 AM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> I was interested to find that ST_AsMVTGeom drops features that fall below
> 1/2 a pixel in size.
> postgis30=# select st_astext(st_asmvtgeom('LINESTRING(10 10, 11 10)',
> 'LINESTRING(0 0, 16384 16384)'::geometry));
> st_astext
> (1 row)
> There's no configuration option to avoid this behaviour, and if you map a
> large enough area that your feature size falls below a pixel you end up
> with big blanks in your map. Have there been no complaints about this
> before?
> P.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
OSM BY Team - http://openstreetmap.by/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210519/bf285570/attachment.html>
