[postgis-devel] 3.1.2 Release
Paragon Corporation
lr at pcorp.us
Fri May 21 12:19:09 PDT 2021
No. +1 to release
On Thu, May 20, 2021 at 4:10 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> We're about 4 months out from our last 3.1 maintenance release and have a
> good backlog of fixes waiting, any objections to a patch release?
> - #4871, TopoGeometry::geometry cast returns NULL for empty
> TopoGeometry objects (Sandro Santilli)
> - #4826, postgis_tiger_geocoder Better answers when no zip is provided
> (Regina Obe)
> - #4817, handle more complex compound coordinate dystems (Paul Ramsey)
> - #4842, Only do axis flips on CRS that have a "Lat" as the first column
> (Paul Ramsey)
> - Support recent Proj versions that have removed pj_get_release (Paul
> Ramsey)
> - #4835, Adjust tolerance for geodetic calculations (Paul Ramsey)
> - #4840, Improper conversion of negative geographic azimuth to positive
> (Paul Ramsey)
> - #4853, DBSCAN cluster not formed when recordset length equal to
> minPoints (Dan Baston)
> - #4863, Update bboxes after scale/affine coordinate changes (Paul
> Ramsey)
> - #4876, Fix raster issues related to PostgreSQL 14 tablefunc changes
> (Paul Ramsey, Regina Obe)
> - #4877, mingw64 PostGIS / PostgreSQL 14 compile (Regina Obe, Tom Lane)
> - #4838, Update to support Tiger 2020 (Regina Obe)
> - #4890, Change Proj cache lifetime to last as long as connection (Paul
> Ramsey)
> - #4845, Add Pg14 build support (Paul Ramsey)
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210521/8cb78f7a/attachment.html>
