[postgis-devel] Docker postgis-build-env ?
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 11 08:29:29 PDT 2022
Someome updated and pushed these recently (2 days ago?) there seems to be something awry in the GDAL and CGAL shipping with some of them, which is causing CI failures on CI that depends on them (GitHub Actions)
https://hub.docker.com/repository/docker/postgis/postgis-build-env
See the results in this PR for example.
https://github.com/postgis/postgis/pull/682
P
