[postgis-devel] [postgis-users] PostGIS 3.3.0 rc1 in about a week
Greg Troxel
gdt at lexort.com
Mon Aug 1 08:27:49 PDT 2022
"Regina Obe" <lr at pcorp.us> writes:
>> share/postgresql/extension/postgis--unpackaged.sql
>> share/postgresql/extension/postgis_raster--unpackaged.sql
>> share/postgresql/extension/postgis_topology--unpackaged.sql
> It's not a bug.
ok, fine with me. The benefits of the packing lists are:
- ensure repeatable builds on various OS and with various sets of
installed things
- be able to check that upstream changes are intended
More than 90% of the time I ask, it's intended. But not always.
> postgis_tiger_geocoder and address_standardizer are not built using the
> utility scripts, so they don't follow the other extensions model completely.
> Those unpackaged versions are built by the utility scripts. I would rather
> postgis_tiger_geocoder and address_standardizer not have those scripts.
> Those were mostly useful for unraveling postgis and postgis_raster (when
> jumping from < 3.0) from each other as I recall. Most people should just be
> using extensions, so there is no need for these. If they per chance were
> using the sql files, they can always convert by dropping the tiger schema
> entirely and the tiger_data schema. It's a lot of data, but those have to
> be reloaded every year to stay current anyway.
I see, and that's ok. Maybe sunset pre-3.0 support? But I suspect
there's a long tail of not-ugpraded systems.
> I notice postgis_sfcgal and address_standardizer are completely missing from
> your list. I assume you don't package those?
Correct, I don't. There is something about standardizer that is
required that I'm not sure about, and I force it off so that I get
repeatable builds (specifically, my system vs a system where *only* the
packages that are declared as dependencies are installed). I should
look at this again; the ball is in my court for sure.
I'm also not sure about sfcgal. I may have to package that first.
Again ball in my court.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220801/d83adcbb/attachment.sig>
