[postgis-devel] The index is not optimal. To optimize it, contact a developer, or try to use the column as the second one in the CREATE INDEX command.
Sandro Santilli
strk at kbt.io
Fri Feb 4 04:52:30 PST 2022
On Fri, Feb 04, 2022 at 01:07:42PM +0100, Sandro Santilli wrote:
> On Fri, Feb 04, 2022 at 02:26:48PM +0300, Darafei "Komяpa" Praliaskouski wrote:
> > What branch is it on?
> Master branch as of commit 0ffe2870eade1a26a1573eb11e7540eacc207783.
> > I touched picksplit on master but it passed the tests fine.
> It's not an error, just a DEBUG with an HINT.
> > This normally can happen if you're pushing dozens of same values into
> > index. I'd also expect it on EMPTY's. May happen if you're having a lot of
> > updates on one row without vacuum collecting stuff.
> Topology building does have a lot of updates of the same rows over and
> over again (and never expliclty runs vacuum). Maybe this would be good
> to change.
Is there now a way to decide which picksplit method to use for a given
index ? Because during execution of topology building function there's
no way to VACUUM becuase changes are all still not committed, so the
index will always (for such batch loads).
--strk;
