[postgis-devel] Proposal for PostgreSQL enhanced extension upgrade handling
Sandro Santilli
strk at kbt.io
Fri Feb 11 09:34:42 PST 2022
Following the thread about the hack of postgis_extensions_upgrade
tagging the current version as "ANY" to reduce dependency on
specific upgrade scripts we install on the system [1] I'm writing
this mail to propose a possible upstream enhancement of the mechanism
by which PostgreSQL looks for upgrade scripts, to help us with keeping
the number of installed files as low as possible (ideally: 1 single
file, as matching our actual upgrade script).
At the moment PostgreSQL checks the current version of an extension
and looks for files in the form:
${extension_name}--${current_version}--${other_version}
And chains them to find a path going from ${current_version}
to ${target_version}.
The proposal is to allow wildcards in the filenames so that
${current_version} doesn't only match ${current_version} but
also matches some more generic string.
An example wildcard which could work for us would be for
example the string '%', which could match "any-sequence-of-characters"
(deriving its meaning from the SQL standard used for LIKE.
If PostgreSQL supported that, we could ship, with any new version
of PostGIS (call it ${version}) only these two files:
- postgis--%--ANY.sql
A 0 bytes file
- postgis--ANY-${version}.sql
Our current single-file upgrade script
The enhanced syntax would not only work for PostGIS but would open
up the possibility for other extension to have upgrade scripts
which are valid for a set of versions, for examples:
- myextension--0.%--1.0.sql
- myextension--0.2.%--0.3.1.sql
The wildcard, in this proposal, should be only accepted in
the "from" part of the filenaming.
What do you think ? Could such proposal be submitted upstream ?
[1] https://trac.osgeo.org/postgis/ticket/5092
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
