[postgis-devel] Postgis 3.3 extension upgrade on AWS RDS Postgres 13.3
'Sandro Santilli'
strk at kbt.io
Tue Feb 15 02:03:53 PST 2022
On Mon, Feb 14, 2022 at 08:46:10PM -0500, Regina Obe wrote:
> AWS doesn’t allow the below. But I think it should work as part of
> the ALTER EXTENSION as you have it in 3.3 as that runs under a higher
> level account.
In 3.3 I had `postgis_extensions_upgrade()` do the UPDATE to
pg_extension. If that's going to error out, under AWS, while
the previous approach worked, we'll probably want to revert that
change.
--strk;
