[postgis-devel] out-of-tree?
Sandro Santilli strk at kbt.io
Tue Feb 15 06:14:10 PST 2022
On Mon, Feb 14, 2022 at 03:35:16PM -0800, Paul Ramsey wrote:
> Should note, all I did was.
>  mkdir postgis-build
>  cd postgis-build
>  ../postgis-git/configure ... etcetc ...
>  make
It's not documented because should be common way.
Can you test ensuring your source tree is clean ?
The VPATH usage may get confused if some files generated
files are in the source tree too. Well-written configure
scripts would refuse to configure from a build tree if
the source tree is "already configured" (I didn't implement
that part, but feel free to file a ticket).
Of course also file a ticket for your problem if it isn't
fixed by cleaning up the source tree.
I will note: Dronie (cloud and osgeo) and gitlab are already
building out-of-tree, so things are known to work there.
--strk;
