[postgis-devel] out-of-tree?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Feb 15 10:29:49 PST 2022
Yeah, I have a dirty tree.
> On Feb 15, 2022, at 6:14 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Feb 14, 2022 at 03:35:16PM -0800, Paul Ramsey wrote:
>> Should note, all I did was.
>> mkdir postgis-build
>> cd postgis-build
>> ../postgis-git/configure ... etcetc ...
>> make
> It's not documented because should be common way.
The build doco in the README.postgis still assumes in-tree building. I didn't check the docbook.
P.
> Can you test ensuring your source tree is clean ?
> The VPATH usage may get confused if some files generated
> files are in the source tree too. Well-written configure
> scripts would refuse to configure from a build tree if
> the source tree is "already configured" (I didn't implement
> that part, but feel free to file a ticket).
> Of course also file a ticket for your problem if it isn't
> fixed by cleaning up the source tree.
> I will note: Dronie (cloud and osgeo) and gitlab are already
> building out-of-tree, so things are known to work there.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
