[postgis-devel] GEOS 3.10.2 Released
Paul Ramsey pramsey at cleverelephant.ca
Sat Jan 15 13:47:01 PST 2022
The latest patch release of GEOS is now available!
http://libgeos.org/usage/download/
Changes in 3.10.2
2022-01-15
- Fixes/Improvements:
  - Fix crash in MonotoneChain with empty CoordinateSequence (GH-539, Sandro Santilli)
  - Fix crash in GeoJSONWriter in case of empty points (TRAC-1139, Paul Ramsey)
  - Improve BuildArea performance (TRAC-1122, Sandro Santilli)
  - Fix unaryUnion to avoid segfault with empty polygon (GH-501, Mike Taves)
  - Fix memory leak on exception in prepared geometry (GH-506, Dan Baston)
  - Iterator invalidation in rare cases (GH-508, Momtchil Momtchev)
  - Infinite loop on collapsed input to MaximumInscribedCircle (Paul Ramsey)
  - Write LinearRing to GeoJSON as LineString (TRAC-1140, Paul Ramsey)
  - Fix PolygonEarClipper to handle collapsed corners (GH-526, Martin Davis)
  - Fix GEOSSTRtree_remove for empty tree (GH-544, Dan Baston)
  - Fix crash on query of STRtree with removed items (GH-545, Dan Baston)
