[postgis-devel] postgis_letters in project tree?
Greg Troxel
gdt at lexort.com
Thu Jan 27 08:52:18 PST 2022
Paul Ramsey <pramsey at cleverelephant.ca> writes:
>> On Jan 27, 2022, at 8:15 AM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
>> It seems that the extension should come with code to process fonts in
>> standard representations, rather than preprocessed fonts. It could
>> then just use fonts already on the system, and it would be both more
>> powerful and smaller.
> The point it me is not font-making or any of that. The point is a
> mechanism for making shapes that people already understand (letters!)
> and thus make good starting points for visual examples of
> geoprocessing, examples they can run themselves and tweak locally. The
> pretty pictures are compelling and explanatory.
> https://www.postgresonline.com/journal/archives/302-Word-Play-with-Spatial-SQL.html
> It's to support postgis documentation, not to provide any real-world
> utility. For me having font processing is not the point. I'd also like
> to find a way to embed the font information into the a simple letter
> generation function, so there's no need for a support table, that's
> how unconcerned I am with things like "changing the font" or
> "customizing the letter table". I just want a functional way to
> generate graphical outputs to feed into other functions to show how
> they work, with known shapes as the input.
I don't really want to process fonts either. Where I was coming from
is:
remove size from the install
avoid licensing issues
So: how much bigger does an installed package get? Are there any
additional dependencies?
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220127/a6b8e6b1/attachment.sig>
