[postgis-devel] postgis_letters in project tree?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jan 27 08:56:51 PST 2022
> On Jan 27, 2022, at 8:52 AM, Greg Troxel <gdt at lexort.com> wrote:
> Paul Ramsey <pramsey at cleverelephant.ca> writes:
>>> On Jan 27, 2022, at 8:15 AM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
>>> It seems that the extension should come with code to process fonts in
>>> standard representations, rather than preprocessed fonts. It could
>>> then just use fonts already on the system, and it would be both more
>>> powerful and smaller.
>> The point it me is not font-making or any of that. The point is a
>> mechanism for making shapes that people already understand (letters!)
>> and thus make good starting points for visual examples of
>> geoprocessing, examples they can run themselves and tweak locally. The
>> pretty pictures are compelling and explanatory.
>> https://www.postgresonline.com/journal/archives/302-Word-Play-with-Spatial-SQL.html
>> It's to support postgis documentation, not to provide any real-world
>> utility. For me having font processing is not the point. I'd also like
>> to find a way to embed the font information into the a simple letter
>> generation function, so there's no need for a support table, that's
>> how unconcerned I am with things like "changing the font" or
>> "customizing the letter table". I just want a functional way to
>> generate graphical outputs to feed into other functions to show how
>> they work, with known shapes as the input.
> I don't really want to process fonts either. Where I was coming from
> is:
> remove size from the install
> avoid licensing issues
> So: how much bigger does an installed package get? Are there any
> additional dependencies?
No deps. The font set in the current postgis_letters repo is 250K
