[postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Sandro Santilli strk at kbt.io
Fri Jan 28 04:14:39 PST 2022
On Fri, Jan 28, 2022 at 12:40:31AM -0500, Regina Obe wrote:
> Sandro,
> Can you remind me, I think you figured out a way around the raster
> unpackaged issue so it works in PG 13 too so it should be possible for
> someone to go straight from say PG 9.x 2.4 to PG 13 3.x
I'm not sure what you're referring to.
The `CREATE FROM UNPACKAGED` syntax was removed from
postgis_extensions_upgrade()
in commit 520af0e8d1bb6e9544d974713bb87e428ff4230b
which seems to be both in 3.1 and 3.2 branches,
not sure it landed in 3.0 (there's no notice of it in the NEWS file)
--strk;
