[postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Nikhil Shetty
nikhil.dba04 at gmail.com
Fri Jan 28 21:50:20 PST 2022
Hi Team,
We have found another method that will help to upgrade both postgresql from
11 to 13 and postgis from 2.5.4 to 3.1.2.
Error:
could not load library "$libdir/postgis-2.5": ERROR: could not access file
"$libdir/postgis-2.5": No such file or directory
Resolution: Create a symlink
cd /usr/pgsql-13/lib
1) ln -s postgis-3.so <http://rtpostgis-2.4.so/> postgis-2.5.so
<http://rtpostgis-2.3.so/>
Once symlink is created proceed with pg_upgrade and it is successful. I
wanted to confirm whether this is the right way to go?
Note: We are not changing the symlink after pg_upgrade.
Thanks,
Nikhil
On Fri, Jan 28, 2022 at 5:44 PM Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Jan 28, 2022 at 12:40:31AM -0500, Regina Obe wrote:
> > Sandro,
> > Can you remind me, I think you figured out a way around the raster
> > unpackaged issue so it works in PG 13 too so it should be possible for
> > someone to go straight from say PG 9.x 2.4 to PG 13 3.x
> I'm not sure what you're referring to.
> The `CREATE FROM UNPACKAGED` syntax was removed from
> postgis_extensions_upgrade()
> in commit 520af0e8d1bb6e9544d974713bb87e428ff4230b
> which seems to be both in 3.1 and 3.2 branches,
> not sure it landed in 3.0 (there's no notice of it in the NEWS file)
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220129/91ef0b3c/attachment.html>
