[postgis-devel] Website Redo change to Hugo
Martin Davis mtnclimb at gmail.com
Thu Mar 3 11:28:49 PST 2022
Great to have the website switched to a modern maintainable platform.
Not sure it's a great idea to keep the 2-column layout though.  It doesn't
seem to be responsive, and I find it visually a bit confusing.
On Thu, Mar 3, 2022 at 10:15 AM Regina Obe <lr at pcorp.us> wrote:
> I've been working on a website redo.
> Main reason is our current https://postgis.net is kinda broken because it
> relies on a PHP CMS framework that is no longer supported and doesn't work
> on newer PHP.
> That said I settled on Hugo seeing the success of grass.osgeo.org and
> libgeos.org.  It also turned out to be very easy to convert our existing
> content to that since our posts and pages are all in markdown already.
> The new site is staged at:
> https://staging.postgis.net
> I plan to move all the RFCs over there once done to the link at the top
> called RFCs.  I've moved the first 2 already
> https://staging.postgis.net/rfcs/
> I still have to fix some of the formatting of old posts and verify the rss
> feed is as we had it before so it works as it did with plant.postgis.net,
> planet.postgresql.org, and planet.osgeo.org.
> Feel free to comment and provide suggestions.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220303/c4f7a296/attachment.html>
