[postgis-devel] PostGIS 3.3.0alpha1 released
Greg Troxel gdt at lexort.com
Sun May 22 06:52:41 PDT 2022
"Regina Obe" <lr at pcorp.us> writes:
> The PostGIS Team is pleased to release PostGIS 3.3.0alpha1!
> This is the first release to support PostgreSQL 15.
I have kicked off a build.
> GEOS 3.6 or higher
> Additional features are enabled if you are running GEOS 3.9+
> ST_MakeValid enhancements with 3.10+, ST_ConcaveHull enhancements with GEOS
> 3.11+
I can't find geos 3.11, and I'm pretty sure that's because it doesn't
exist.   Might be good to say "recent unreleased geos" to give the
right impression.
> The new --enable-lto flag improves math computations.  This new feature is
> disabled by default.
This is a little mysterious to me.  But I am guessing that the feature
itself in compilers is flaky (meaning that for valid programs it fails
to get the correct result).  I'll give it a try after the regular build.
> Details here:  https://postgis.net/2022/05/21/postgis-3.3.0alpha1/
I found the link to the tarball there :-)
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220522/c0383bdc/attachment.sig>
