[postgis-devel] manpages
Greg Troxel
gdt at lexort.com
Wed May 25 05:12:56 PDT 2022
Sandro Santilli <strk at kbt.io> writes:
>> > pkgsrc puts man pages in e.g. /usr/pkg/man/man1/foo.1 and we pass
>> > --mandir to GNU autoconf. So I think the short answer to your question
>> > is that if there's a reaonable knob (configure arg, env var) to say
>> > where the mandir is, a packager calls that a win and doesn't complain.
>> Thanks for reporting this. I'm just afraid it's out of luck if that
>> still works (bots are not checking after it).
> I just tried passing --mandir=/usr/local/share/man/ but I don't find
> any of PostGIS manpages under /usr/local/share/man/ after running
> `make install`. Are you sure --mandir is ALL you use in pkgsrc ?
> Is this against the master branch ?
My report was against 3.3.0rc1.
I did not mean to say this was a regression from previous versions.
The actual configure call sets a ton of environment variables and then
./configure --enable-rpath --datadir=/usr/pkg/share/postgresql/contrib --without-address-standardizer -with-xsldir=/usr/pkg/share/xsl/docbook --x-includes=/usr/X11R7/include --x-libraries=/usr/X11R7/lib --prefix=/usr/pkg --build=x86_64--netbsd --host=x86_64--netbsd --mandir=/usr/pkg/man --enable-option-checking=yes
(I can send you the entire >1MB debug build log if you want.)
This follows from the package control file having:
GNU_CONFIGURE= yes
CONFIGURE_ARGS+= --enable-rpath
CONFIGURE_ARGS+= --datadir=${PREFIX}/share/postgresql/contrib
This setting of mandir generally works on (other) autoconf packages.
I think the root cause of the trouble is a blend of autoconf in postgis
and pgxs.mk
But I don't even get man pages in /usr/pkg/share/man/man1 (which is a
normal path and probably the autconf default for --prefix=/usr/pkg). If
I did, I would have just patched a makefile to change the path.
Do you get man pages at all? Is there something I can pass to
configure, put in the configure env, or the build env, that will install
them? README.postgis says default is $prefix/man....
Maybe I should just add something like (but actually get it right)
post-install:
$(INSTALL_MAN) $(WRKSRC)/doc/man/shp2pgsql.1 $(DESTDIR)$(MANDIR)/man1
if man page installation just generally doesn't work. That's the usual
pkgsrc workaround for things the upstream package's build system should
have installed but did not.
I wonder though if postgis, in using pgxs, should be in essence forcing
all paths to be the paths postgresql was built with, and not pretend
otherwise. I see now that there is no man page for psql installed
either. So maybe this is an issue in how postgresql is munged in pkgsrc.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220525/ced54058/attachment.sig>
