[postgis-devel] Small memory leak in function BOX2D_to_LWGEOM
Esteban Zimanyi esteban.zimanyi at ulb.be
Sat Sep 10 00:48:45 PDT 2022
PG_FUNCTION_INFO_V1(BOX2D_to_LWGEOM);
Datum BOX2D_to_LWGEOM(PG_FUNCTION_ARGS)
  GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
  POINTARRAY *pa = ptarray_construct_empty(0, 0, 5); // <----------------
  POINT4D pt;
  GSERIALIZED *result;
  if ( (box->xmin == box->xmax) && (box->ymin == box->ymax) )
    /* pa is NOT used */;
  else if ( (box->xmin == box->xmax) || (box->ymin == box->ymax) )
    /* ONLY case where pa is used */;
  else
    POINT4D points[4];
    LWPOLY *poly;
    /* Initialize the 4 vertices of the polygon */
    /* A new pa is created in the following function call <-------------- */;
    /* Construct polygon */
    poly = lwpoly_construct_rectangle(LW_FALSE, LW_FALSE, &points[0],
&points[1],
        &points[2], &points[3]);
    result = geometry_serialize(lwpoly_as_lwgeom(poly));
    lwpoly_free(poly);
  PG_RETURN_POINTER(result);
A possible solution would be
  // Declaration removed <-------------------------
  POINT4D pt;
    /* As before <----------------- */;
    LWLINE *line;
    POINTARRAY *pa = ptarray_construct_empty(0, 0, 2); //
  else
