[postgis-devel] Small memory leak in function BOX2D_to_LWGEOM
Raúl Marín
raul at rmr.ninja
Sat Sep 10 06:32:29 PDT 2022
For the most part, there is no need to free memory in PG functions as it
will be freed once the allocation arena as a whole is freed.
There are some exceptions, like when working with huge allocations,
recursion (lots of allocations) or memory not handled by PG, but AFAICS
this one is not one of those.
In any case, if you actually detect the leak and have a way to reproduce
it it'd be worth investigating, because this or similar patterns are
present in many other functions.
El 10/09/2022 a las 9:48, Esteban Zimanyi escribió:
> PG_FUNCTION_INFO_V1(BOX2D_to_LWGEOM);
> Datum BOX2D_to_LWGEOM(PG_FUNCTION_ARGS)
> GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
> POINTARRAY *pa = ptarray_construct_empty(0, 0, 5); // <----------------
> POINT4D pt;
> GSERIALIZED *result;
> if ( (box->xmin == box->xmax) && (box->ymin == box->ymax) )
> /* pa is NOT used */;
> else if ( (box->xmin == box->xmax) || (box->ymin == box->ymax) )
> /* ONLY case where pa is used */;
> else
> POINT4D points[4];
> LWPOLY *poly;
> /* Initialize the 4 vertices of the polygon */
> /* A new pa is created in the following function call <-------------- */;
> /* Construct polygon */
> poly = lwpoly_construct_rectangle(LW_FALSE, LW_FALSE, &points[0],
> &points[1],
> &points[2], &points[3]);
> result = geometry_serialize(lwpoly_as_lwgeom(poly));
> lwpoly_free(poly);
> PG_RETURN_POINTER(result);
> A possible solution would be
> // Declaration removed <-------------------------
> POINT4D pt;
> /* As before <----------------- */;
> LWLINE *line;
> POINTARRAY *pa = ptarray_construct_empty(0, 0, 2); //
> else
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
