[postgis-devel] Coverage Functions
Martin Davis
mtnclimb at gmail.com
Fri Apr 28 14:57:35 PDT 2023
On Fri, Apr 28, 2023 at 7:18 AM Sandro Santilli <strk at kbt.io> wrote:
> As mentioned in chat, I'm thinking having a GEOSCoverage
> datatype would be advisible here, with one constructor
> taking a vector of Geometry pointer for now but eventually
> getting more constructors.
Sandro, are you suggesting a GEOSCoverage type containing a *topological*
structure, or one containing a set of Polygons/MultiPolygons?
For a topological structure, that may be useful, but that is a fair bit of
work and is NOT required by the recent coverage functions. If and when
this is done, I suggest it is called GEOSTopology to be totally clear.
For a coverage type that simply contains a list of polygonal geometries,
that is what I have called a Simple Features Coverage. GEOSCoverage would
be a fine name for this. This is actually what I considered at the start
of developing the various coverage operations. I backed away from this in
order to keep things simple. But it does have some advantages for
understanding and documenting the concept of a simple coverage.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230428/0f47e58e/attachment.htm>
