[postgis-devel] [postgis-users] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
Nikhil Shetty nikhil.dba04 at gmail.com
Wed Aug 23 19:54:46 PDT 2023
Hi Regina,
We do have plans to upgrade both Postgres and PostGIS to higher versions
but currently we are focusing on OS upgrade to RHEL8
Do you think being on PostGIS 3.1.2 will impact OS upgrade? Are there any
known issues
Thanks,
Nikhil
On Wed, 23 Aug 2023 at 23:41, Regina Obe <lr at pcorp.us> wrote:
> 3.1.2 is not the latest stable release for 3.1, so you really shouldn’t be
> using that.  The 3.1.2 is before the PostgreSQL security vulnerability
> patches for example and numerous bugs have been fixed since then.
> Latest 3.1 is 3.1.9
> https://postgis.net/2023/05/PostGIS-3.3.3-3.2.5-3.1.9-3.0.9-Patch-Releases/
> News specific for 3.1 -
> https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.9/NEWS
> I would say the same holds true for PostgreSQL 13.12 is the latest stable,
> so not sure why you are trying to use a version several micro updates behind
> https://www.postgresql.org/about/news/postgresql-154-149-1312-1216-1121-and-postgresql-16-beta-3-released-2689/
> Hope that helps,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Nikhil Shetty
> *Sent:* Wednesday, August 23, 2023 2:02 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>;
> postgis-users at lists.osgeo.org
> *Subject:* [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
> Hi Team,
> We want to know if there are any open/known issues that we may face
> post-migration of the Postgres database  instance  with PostGIS enabled
> from centos7/RHEL7/OEL7 to RHEL8.
> We came across one issue regarding collation(
> https://wiki.postgresql.org/wiki/Locale_data_changes), the solution for
> which is to reindex or use logical replication. This is not related to
> PostGIS but still a concern causing index corruption
> In a similar way, we want to understand if there are any other known
> issues related to PostGIS that should be taken care of
> PostgreSQL : 13.6
> PostGIS : 3.1.2
> Thanks and Regards,
> Nikhil
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230824/c97a299d/attachment.htm>
