[postgis-devel] [postgis-users] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
Nikhil Shetty nikhil.dba04 at gmail.com
Fri Aug 25 01:02:55 PDT 2023
Hi Regina,
Please let us know if upgrading to RHEL8 with 3.1.2 would be an issue or
any other known issues with PostGIS
Thanks,
Nikhil
On Thu, 24 Aug 2023 at 08:24, Nikhil Shetty <nikhil.dba04 at gmail.com> wrote:
> Hi Regina,
> We do have plans to upgrade both Postgres and PostGIS to higher versions
> but currently we are focusing on OS upgrade to RHEL8
> Do you think being on PostGIS 3.1.2 will impact OS upgrade? Are there any
> known issues
> Thanks,
> Nikhil
> On Wed, 23 Aug 2023 at 23:41, Regina Obe <lr at pcorp.us> wrote:
>> 3.1.2 is not the latest stable release for 3.1, so you really shouldn’t
>> be using that.  The 3.1.2 is before the PostgreSQL security vulnerability
>> patches for example and numerous bugs have been fixed since then.
>> Latest 3.1 is 3.1.9
>> https://postgis.net/2023/05/PostGIS-3.3.3-3.2.5-3.1.9-3.0.9-Patch-Releases/
>> News specific for 3.1 -
>> https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.9/NEWS
>> I would say the same holds true for PostgreSQL 13.12 is the latest
>> stable, so not sure why you are trying to use a version several micro
>> updates behind
>> https://www.postgresql.org/about/news/postgresql-154-149-1312-1216-1121-and-postgresql-16-beta-3-released-2689/
>> Hope that helps,
>> Regina
>> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
>> Behalf Of *Nikhil Shetty
>> *Sent:* Wednesday, August 23, 2023 2:02 PM
>> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>;
>> postgis-users at lists.osgeo.org
>> *Subject:* [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
>> Hi Team,
>> We want to know if there are any open/known issues that we may face
>> post-migration of the Postgres database  instance  with PostGIS enabled
>> from centos7/RHEL7/OEL7 to RHEL8.
>> We came across one issue regarding collation(
>> https://wiki.postgresql.org/wiki/Locale_data_changes), the solution for
>> which is to reindex or use logical replication. This is not related to
>> PostGIS but still a concern causing index corruption
>> In a similar way, we want to understand if there are any other known
>> issues related to PostGIS that should be taken care of
>> PostgreSQL : 13.6
>> PostGIS : 3.1.2
>> Thanks and Regards,
>> Nikhil
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230825/86e8f606/attachment.htm>
