[postgis-devel] Separate make target to install extension upgrade scripts ?
Regina Obe
lr at pcorp.us
Thu Jan 26 23:13:41 PST 2023
> > As a package, if you can tell WHICH older version is going to be
> > removed, you could just run:
> > postgis install-extension-upgrades $OLDVERSION
> > after having installed the new version.
> Interesting, but for pkgsrc we really can't tell what the old version was.
Strk I'm still a bit lost with all of this.
I doubt if packagers will ever know what version a user is running
And users are not going to be able to run the postgis command line.
So answer me this:
You can have the default not install anything, I think that's fine for users
who compile their own
And people can still upgrade with:
SELECT postgis_extensions_upgrade();
Right without scripts?
Then have an all option so I don't need to do the match to figure out what
to put in from..to etc.
Then I assume I can do:
postgis install-extension-upgrades all --pg_sharedir /tmp/share/extension
BTW I tried running
postgis --help
and got an error.
The issue is when I installed it gave it a name postgis.exe, but it's not an
executable, it's a perl script.
So I had to get rid of the exe extension (cause it thinks it a 16-bit app)
perl postgis --help
Any reason you can't just give a .pl extension?
I'll file a ticket.
Thanks,
Regina
