[postgis-devel] An any spatial type that works for geometry / geography
Paul Ramsey pramsey at cleverelephant.ca
Tue Jan 31 14:14:33 PST 2023
The main thing (?) I think we've had problems with in geometry/geography casting is that even if we can avoid issues of conflicts on types in the input side, the output of the default function signatures is always geometry... so
ST_StartPoint(geography) -> ST_StartPoint(geometry) returns geometry
I haven't done the research, but the idea of a polymorphic function feels "kinda right?" you feet ST_StartPoint(geography) -> ST_StartPoint(anygeo) returns anygeo and then returns geography. Magic occurs.
Big problem I see is how much function redefinition it requires. Like all of them. So take our "changing aggregate signatures breaks / drops views" problem, and multiply by 100. Not sure how we get around that.
P
> On Jan 31, 2023, at 12:17 PM, Regina Obe <lr at pcorp.us> wrote:
> We've had this issue for a long time that many functions that can work just
> as easily for geography require geography to be cast to geometry to use
> them.
> This we've been discussing on #Postgis irc what to do.
> There have been the usual suspects bandied about for years:
> 1) Just define the functions for geography -- this balloons our list of
> functions, making it hard to browse the list in psql/pgadmin and also adds
> technical debt, way more redundant functions to wade thru and patch in our
> scripts.
> 2) Define an autocast from geography to geometry - this causes much
> unpredicatability.
> Note we already have an autocast from geometry -> geography, but that is
> less of a concern
> Since if a geometry is not in spheroidal spatial ref, the autocast fails.
> The geography would just silently pass and do an unexpected horrible thing
> that wouldn't be discovered until some plane crashes.
> My final thought is the cleanest way to do this is with an anypostgisvector
> or some such thing and for select functions that underlying logic is the
> same for both planar and spheroidal, would allow either in.
> Right now I can test the theory out by for example,
> Defining a st_pointn variant
> CREATE OR REPLACE FUNCTION test_st_pointn(anyelement,integer)
>    RETURNS anyelement
>    LANGUAGE 'c'
>    COST 50
>    IMMUTABLE STRICT PARALLEL SAFE
> AS '$libdir/postgis-3', 'LWGEOM_pointn_linestring';
> And with that, I can do
>  SELECT test_st_pointn(ST_GeomFromText('LINESTRING(1 2, 3 4, 5 6)'),1); ->
> returns a geometry
> SELECT test_st_pointn(ST_GeogFromText('LINESTRING(1 2, 3 4, 5 6)'),1); ->
> returns a geography
> The only thing I don't like about the above, is then it will also match any
> gibberish like
> SELECT test_st_pointn('hello there'::text,1);
> ERROR:  Unknown geometry type: 231 - Invalid typeSQL state: XX000
> Or
>  SELECT test_st_pointn(ST_AsGeoJSON(ST_GeomFromText('LINESTRING(1 2, 3 4, 5
> 6)')),1);
> ERROR:  Unknown geometry type: 1920226149 - Invalid type
> SQL state: XX000
> But hey, at least it returns an error.
> So perhaps just using the anyelement type for these cases isn't horrible
> especially if we've tested in the face of dangerous inputs.
> The only downside of this, is it would require dropping our geometry type
> functions that under the plumbing should call the same for geography and
> replacing with an anyelement type.
> I'm not sure how hard it would be to create our own type that just targets
> geometry and geography.  That I think would be cleaner if it's not too much
> trouble.
> Anyone see issues with this idea?
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
