[postgis-devel] An any spatial type that works for geometry / geography
Regina Obe
lr at pcorp.us
Tue Jan 31 14:33:48 PST 2023
Yah that was my concern too, well it wouldn't be all of them, just a lot of
them.
Strk has a nifty trick in place to at least handle this for upgrading where
he has
logic to rename the old function swap in the new function and notify people
that they have views that need to be updated (assuming anyone pays attention
to those notices).
Strk I now there was a reason we just don't replace the views, I forget the
reason something about check options? I now we can't replace materialized
views since there is no CREATE OR REPLACE MATERIALIZED VIEW command.
So I was thinking we could experiment with things people probably rarely
use.
Like the case of geometrytype(geometry) , geometrytype(geography)
Which we already have two versions of and I suspect it might only be used in
our own views, if it's used their at all. So get rid of the both and replace
with geometrytype(anygeo).
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
Behalf
> Of Paul Ramsey
> Sent: Tuesday, January 31, 2023 5:15 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] An any spatial type that works for geometry /
> geography
> The main thing (?) I think we've had problems with in geometry/geography
> casting is that even if we can avoid issues of conflicts on types in the
input side,
> the output of the default function signatures is always geometry... so
> ST_StartPoint(geography) -> ST_StartPoint(geometry) returns geometry
> I haven't done the research, but the idea of a polymorphic function feels
> "kinda right?" you feet ST_StartPoint(geography) -> ST_StartPoint(anygeo)
> returns anygeo and then returns geography. Magic occurs.
> Big problem I see is how much function redefinition it requires. Like all
of
> them. So take our "changing aggregate signatures breaks / drops views"
> problem, and multiply by 100. Not sure how we get around that.
> P
> > On Jan 31, 2023, at 12:17 PM, Regina Obe <lr at pcorp.us> wrote:
> > We've had this issue for a long time that many functions that can work
> > just as easily for geography require geography to be cast to geometry
> > to use them.
> > This we've been discussing on #Postgis irc what to do.
> > There have been the usual suspects bandied about for years:
> > 1) Just define the functions for geography -- this balloons our list
> > of functions, making it hard to browse the list in psql/pgadmin and
> > also adds technical debt, way more redundant functions to wade thru
> > and patch in our scripts.
> > 2) Define an autocast from geography to geometry - this causes much
> > unpredicatability.
> > Note we already have an autocast from geometry -> geography, but that
> > is less of a concern Since if a geometry is not in spheroidal spatial
> > ref, the autocast fails.
> > The geography would just silently pass and do an unexpected horrible
> > thing that wouldn't be discovered until some plane crashes.
> > My final thought is the cleanest way to do this is with an
> > anypostgisvector or some such thing and for select functions that
> > underlying logic is the same for both planar and spheroidal, would allow
> either in.
> > Right now I can test the theory out by for example,
> > Defining a st_pointn variant
> > CREATE OR REPLACE FUNCTION test_st_pointn(anyelement,integer)
> > RETURNS anyelement
> > LANGUAGE 'c'
> > COST 50
> > IMMUTABLE STRICT PARALLEL SAFE
> > AS '$libdir/postgis-3', 'LWGEOM_pointn_linestring';
> > And with that, I can do
> > SELECT test_st_pointn(ST_GeomFromText('LINESTRING(1 2, 3 4, 5
> > 6)'),1); -> returns a geometry SELECT
> > test_st_pointn(ST_GeogFromText('LINESTRING(1 2, 3 4, 5 6)'),1); ->
> > returns a geography
> > The only thing I don't like about the above, is then it will also
> > match any gibberish like
> > SELECT test_st_pointn('hello there'::text,1);
> > ERROR: Unknown geometry type: 231 - Invalid typeSQL state: XX000 Or
> > SELECT test_st_pointn(ST_AsGeoJSON(ST_GeomFromText('LINESTRING(1 2,
> 3
> > 4, 5 6)')),1);
> > ERROR: Unknown geometry type: 1920226149 - Invalid type SQL state:
> > XX000
> > But hey, at least it returns an error.
> > So perhaps just using the anyelement type for these cases isn't
> > horrible especially if we've tested in the face of dangerous inputs.
> > The only downside of this, is it would require dropping our geometry
> > type functions that under the plumbing should call the same for
> > geography and replacing with an anyelement type.
> > I'm not sure how hard it would be to create our own type that just
> > targets geometry and geography. That I think would be cleaner if it's
> > not too much trouble.
> > Anyone see issues with this idea?
> > Thanks,
> > Regina
> > postgis-devel mailing list
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
