[postgis-devel] How about a 3.3.4 release, for topology improvements ?
Sandro Santilli
strk at kbt.io
Thu Jul 6 09:24:10 PDT 2023
There's a serious topology bug fixed in the 3.3 branch which didn't
make it into 3.3.3, plus a few more:
* Bug Fixes and Enhancements *
- #5395, [postgis_topology] Allow unprivileged user dump
of database with topology enabled
- #5394, [postgis_topology] Improve robustness of finding
distinct vertices in topology edges (Sandro Santilli)
- #5403, [postgis_topology] Fix ValidateTopology(bbox) without
topology in search_path (Sandro Santilli)
- #5410, [postgis_raster] ST_Value bilinear resample,
don't throw an error if Band has no NODATA value
(Regina Obe)
- #5385, Postgres malloc assertion fail when
using pg_cancel_backend with ST_AsMVT
(Regina Obe, Paul Ramsey)
* Breaking Changes *
- #5385, Take out interruptability of ST_AsMVT
as it causes backend crash under intense conditions
Trac is 1 ticket left 3.3.4:
https://trac.osgeo.org/postgis/query?status=assigned&status=new&status=reopened&milestone=PostGIS+3.3.4&group=status&order=priority
- #5408 regression failure on tiger geocoder pagc_normalize_address
Are you ok with pushing that forward and cutting a 3.3.4 releease ?
I can do it, if you're ok with it. Note that #5395 was a regression
introduced in 3.3.3 (not present in 3.3.2).
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
