[postgis-devel] How about a 3.3.4 release, for topology improvements ?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jul 6 09:25:45 PDT 2023
I’m always fine w/ a maintenance release.
Not sure that the wagyu interrupt thing is a “breaking change”, not sure what it would break, it just means there might be slightly more delay in an interrupt in the very rare case that wagyu is actually taking a lot of time.
P
> On Jul 6, 2023, at 9:24 AM, Sandro Santilli <strk at kbt.io> wrote:
> There's a serious topology bug fixed in the 3.3 branch which didn't
> make it into 3.3.3, plus a few more:
> * Bug Fixes and Enhancements *
> - #5395, [postgis_topology] Allow unprivileged user dump
> of database with topology enabled
> - #5394, [postgis_topology] Improve robustness of finding
> distinct vertices in topology edges (Sandro Santilli)
> - #5403, [postgis_topology] Fix ValidateTopology(bbox) without
> topology in search_path (Sandro Santilli)
> - #5410, [postgis_raster] ST_Value bilinear resample,
> don't throw an error if Band has no NODATA value
> (Regina Obe)
> - #5385, Postgres malloc assertion fail when
> using pg_cancel_backend with ST_AsMVT
> (Regina Obe, Paul Ramsey)
> * Breaking Changes *
> - #5385, Take out interruptability of ST_AsMVT
> as it causes backend crash under intense conditions
> Trac is 1 ticket left 3.3.4:
> https://trac.osgeo.org/postgis/query?status=assigned&status=new&status=reopened&milestone=PostGIS+3.3.4&group=status&order=priority
> - #5408 regression failure on tiger geocoder pagc_normalize_address
> Are you ok with pushing that forward and cutting a 3.3.4 releease ?
> I can do it, if you're ok with it. Note that #5395 was a regression
> introduced in 3.3.3 (not present in 3.3.2).
> --strk;
> Libre GIS consultant/developer
> https://strk.kbt.io/services.html
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
