[postgis-devel] 3.4 Meet To Do - NOTE to packagers
Regina Obe lr at pcorp.us
Mon Jun 19 11:48:40 PDT 2023
Speaking of Proj items below.
Note to packagers:
Do you build proj > 7 ?
If you build proj
1) Do you have it built with curl support
2) If you have built with curl support
   Do you have the default set to PROJ_NETWORK=ON?
3) If you do neither of the above, how much of the https://cdn.proj.org/
Do you ship?
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
Behalf
> Of Paul Ramsey
> Sent: Monday, June 19, 2023 12:27 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: [postgis-devel] 3.4 Meet To Do
> Thanks for meeting this morning/afternoon/evening to plan the path to 3.4
> Here's the "minutes"
> # PostGIS Meeting, July 19
> * GEOS Release of 3.12
>   * Release by Jun 24
> * PROJ 9.2 and PROJ_NETWORK=ON
>   * new ticket for visibility of network status of proj
>   * find out of proj is built by pgdg with curl
>   * write up a "how to update to proj 9.x" document for packagers
(pramsey)
> * PostGIS 3.4.0 Plans
>   * 5254 Address standardizer put back regression tests #5254 (strk will
take
> on)
>   * 5316 proj regression tests (robe will fix)
>   * 5341 robe will close
>   * 5370 robe will close
>   * 5397 robe will close
>   * All 3.4 tickets to be gardened (close, punt, fix) by July 19 (all
agree!)
> * Release targeting late August / early September
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
