[postgis-devel] [postgis-users] Error Upgrading PostGIS 2.5.4 to 3.1.2
Sandro Santilli
strk at kbt.io
Mon May 15 09:29:05 PDT 2023
On Mon, May 15, 2023 at 03:18:37PM +0530, Nikhil Shetty wrote:
> Hi Sandro,
> I see the ticket https://trac.osgeo.org/postgis/ticket/5380#ticket is
> closed, what did we do to fix it and on which version ?
As you can read in the ticket a fix was pushed to all branches from
3.1 (3.1.9dev) to current master.
The fix was to properly document which functions were replaced by
which new name. Your additional function names will help fixing those
cases too before cutting a new release.
> With this fix, if I do the upgrade, will it do the upgrade without errors ?
I think your new errors (st_combine_bbox) would still need a fix, but
I didn't see a ticket for them ?
--strk;
