[postgis-devel] [postgis-users] Error Upgrading PostGIS 2.5.4 to 3.1.2
Nikhil Shetty
nikhil.dba04 at gmail.com
Thu May 18 20:00:01 PDT 2023
I am not able to access this page - https://trac.osgeo.org/postgis, will
file a ticket once it is accessible.
Thanks,
Nikhil
On Mon, May 15, 2023 at 9:59 PM Sandro Santilli <strk at kbt.io> wrote:
> On Mon, May 15, 2023 at 03:18:37PM +0530, Nikhil Shetty wrote:
> > Hi Sandro,
> > I see the ticket https://trac.osgeo.org/postgis/ticket/5380#ticket is
> > closed, what did we do to fix it and on which version ?
> As you can read in the ticket a fix was pushed to all branches from
> 3.1 (3.1.9dev) to current master.
> The fix was to properly document which functions were replaced by
> which new name. Your additional function names will help fixing those
> cases too before cutting a new release.
> > With this fix, if I do the upgrade, will it do the upgrade without
> errors ?
> I think your new errors (st_combine_bbox) would still need a fix, but
> I didn't see a ticket for them ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230519/c4fd7502/attachment.htm>
