[postgis-devel] [postgis-users] Error Upgrading PostGIS 2.5.4 to 3.1.2
Regina Obe
lr at pcorp.us
Fri May 19 04:29:26 PDT 2023
We are still having some issues with osgeo.org DNS.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nikhil Shetty
Sent: Thursday, May 18, 2023 11:00 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>; Nikhil Shetty <nikhil.dba04 at gmail.com>
Subject: Re: [postgis-devel] [postgis-users] Error Upgrading PostGIS 2.5.4 to 3.1.2
I am not able to access this page - https://trac.osgeo.org/postgis, will file a ticket once it is accessible.
Thanks,
Nikhil
On Mon, May 15, 2023 at 9:59 PM Sandro Santilli <strk at kbt.io <mailto:strk at kbt.io> > wrote:
On Mon, May 15, 2023 at 03:18:37PM +0530, Nikhil Shetty wrote:
> Hi Sandro,
> I see the ticket https://trac.osgeo.org/postgis/ticket/5380#ticket is
> closed, what did we do to fix it and on which version ?
As you can read in the ticket a fix was pushed to all branches from
3.1 (3.1.9dev) to current master.
The fix was to properly document which functions were replaced by
which new name. Your additional function names will help fixing those
cases too before cutting a new release.
> With this fix, if I do the upgrade, will it do the upgrade without errors ?
I think your new errors (st_combine_bbox) would still need a fix, but
I didn't see a ticket for them ?
--strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230519/38d3356f/attachment.htm>
