[postgis-devel] PSC Vote: Release PostGIS 3.3.3, 3.2.5, 3.1.9, 3.0.9 in a week or 2
Imre Samu
pella.samu at gmail.com
Tue May 16 11:35:03 PDT 2023
> a patch release,
Hi Regina,
I recently needed to upgrade to Alpine3.18 [1] (
https://github.com/postgis/docker-postgis/pull/343 ),
and the current version of Postgis (3.3.2) with the default PROJ 9.2 did
not pass the regression test.
Because of this, I had to install some additional PROJ data [2].
The problem is documented ( https://trac.osgeo.org/postgis/ticket/5316 ),
but it seems there's no solution yet.
It might be helpful to warn users about this issue in the changeset.
It's also worth mentioning that PostgreSQL still doesn't work with LLVM 16;
[3]
this issue sometimes only becomes apparent during the PostGIS regression
test [4] or when running the application.
Based on my experience so far, due to its fast update cycles,
Alpine behaves like a 'canary in the coal mine' - revealing problems early
on.
Regards,
Imre
[1] Alpine Linux 3.18 - released on 2023-05-09 with PROJ 9.2, LLVM 16
[2] projsync --system-directory --file ch_swisstopo_CHENyx06_ETRS
projsync --system-directory --file us_noaa_eshpgn
projsync --system-directory --file us_noaa_prvi
projsync --system-directory --file us_noaa_wmhpgn
[3] https://github.com/docker-library/postgres/pull/1077
https://www.postgresql.org/message-id/flat/17927-2d7146227560bdf3%40postgresql.org
[4]
https://github.com/docker-library/postgres/issues/1076#issuecomment-1545209600
LLVMBuildGEP:
symbol not found
Regina Obe <lr at pcorp.us> ezt írta (időpont: 2023. máj. 16., K, 0:16):
> It's been about 6 months since we've had a patch release, and quite a few
> fixes have
> happened since then.
> I'd like to push out another release in about a week or 2.
> Anyone have issues with that.
> +1 for me for a release.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230516/e3858489/attachment.htm>
