[postgis-devel] PSC Vote: Release PostGIS 3.3.3, 3.2.5, 3.1.9, 3.0.9 in a week or 2
Regina Obe lr at pcorp.us
Tue May 16 14:38:56 PDT 2023
Imre,
Thanks for the notes.  I’ll make sure to make note of it in the release notes.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Imre Samu
Sent: Tuesday, May 16, 2023 2:35 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] PSC Vote: Release PostGIS 3.3.3, 3.2.5, 3.1.9, 3.0.9 in a week or 2
>  a patch release,
Hi Regina,
I recently needed to upgrade to Alpine3.18 [1] ( https://github.com/postgis/docker-postgis/pull/343 ),
and the current version of Postgis (3.3.2) with the default PROJ 9.2 did not pass the regression test.
Because of this, I had to install some additional PROJ data [2].
The problem is documented ( https://trac.osgeo.org/postgis/ticket/5316 ), but it seems there's no solution yet.
It might be helpful to warn users about this issue in the changeset.
It's also worth mentioning that PostgreSQL still doesn't work with LLVM 16; [3]
this issue sometimes only becomes apparent during the PostGIS regression test [4]  or when running the application.
Based on my experience so far, due to its fast update cycles,
Alpine behaves like a 'canary in the coal mine' - revealing problems early on.
Regards,
  Imre
[1]  Alpine Linux 3.18 - released on 2023-05-09 with PROJ 9.2, LLVM 16
[2]  projsync --system-directory --file ch_swisstopo_CHENyx06_ETRS
   projsync --system-directory --file us_noaa_eshpgn
   projsync --system-directory --file us_noaa_prvi
   projsync --system-directory --file us_noaa_wmhpgn
[3] https://github.com/docker-library/postgres/pull/1077
     https://www.postgresql.org/message-id/flat/17927-2d7146227560bdf3%40postgresql.org
[4] https://github.com/docker-library/postgres/issues/1076#issuecomment-1545209600  LLVMBuildGEP: symbol not found
Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > ezt írta (időpont: 2023. máj. 16., K, 0:16):
It's been about 6 months since we've had a patch release, and quite a few
fixes have
happened since then.
I'd like to push out another release in about a week or 2.
Anyone have issues with that.
+1 for me for a release.
Thanks,
Regina
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230516/a1dbaf9b/attachment.htm>
