Mailing list configuration updated (was: DMARC/DKIM mitigation on maling lists)
Sandro Santilli
strk at kbt.io
Tue Nov 14 01:36:06 PST 2023
Given nobody complained about the proposal, I've changed the configuration
of this mailing list following the reccomendations of the OSGeo SAC team,
please let me know if you have any problem with this.
--strk;
On Wed, Nov 08, 2023 at 11:21:30AM +0100, 'Sandro Santilli' via postgis-devel wrote:
> On Thu, Oct 26, 2023 at 09:43:44AM +0200, 'Sandro Santilli' via postgis-devel wrote:
> > I like discussing before voting, let's have a test with postgis-tickets
> > and maybe we'll extend the test to other list ?
> > Ideally someone using DKIM/DMARC to send mail will be able to evaluate
> > effects of that change.
> We made the test and it was successful.
> The DKIM signatures of senders were not ruined by taking the steps
> described here:
> https://trac.osgeo.org/osgeo/ticket/3011#comment:23
> How do the subscribers of this list feel about taking those steps
> for this list ? The consequence would be:
> 1. No more [postgis-devel] suffix in the Subject
> 2. No more footer in each message
> 3. Always have From/Reply-To/Sender headers
> If you use subject-based filters to organize your email you could
> update them to use the List-Id header instead, which contains
> (already) this string:
> PostGIS Development Discussion <postgis-devel.lists.osgeo.org>
> --strk;
