[postgis-devel] DMARC/DKIM mitigation on maling lists
Magnus Hagander magnus at hagander.net
Fri Oct 27 01:24:25 PDT 2023
On Fri, Oct 27, 2023 at 10:20 AM Sandro Santilli <strk at kbt.io> wrote:
> [ moving conversation to SAC mailing list as I think it belongs there ]
> On Thu, Oct 26, 2023 at 02:08:45PM +0200, Sandro Santilli via postgis-devel wrote:
> > Ok, this is now live for postgis-tickets. I had to:
> >   1. Set "Replace the From" to "no"
> >      https://lists.osgeo.org/mailman/admin/postgis-tickets/general
> >   2. Disable "Reply-to" munging
> >   3. Remove footer from the non-digest options
> >      https://lists.osgeo.org/mailman/admin/postgis-tickets/nondigest
> > You can see the subsequente differences from the archive:
> > https://lists.osgeo.org/pipermail/postgis-tickets/2023-October/date.html
> Laurențiu (in Cc) tested sending a DKIM-signed email to the
> postgis-tickets configured as mentioned above and the mail was found
> to still break the DKIM signature.
> Here's what I get as Authentication-Results header when the mail arrives
> to my mailbox:
>         Authentication-Results:
>                 dkim=fail ("headers rsa verify failed") header.d=dend.ro header.s=fm2 header.b="HQmGmY/I";
>                 dkim=fail ("headers rsa verify failed") header.d=messagingengine.com header.s=fm3 header.b=o8qZA0x2;
>                 dmarc=fail reason="SPF not aligned (relaxed)" header.from=dend.ro (policy=quarantine);
>                 spf=pass
> Magnus: if we wanted to compare with PostgreSQL lits, would any of
> those lists be good test targets ?
We actually have a testlist we could use for this, as it's currently
not used. I can subscribe you (strk at kbt.io presumably) to it - should
I add anybody else as well? (It currently has just me on it).
 Magnus Hagander
 Me: https://www.hagander.net/
 Work: https://www.redpill-linpro.com/
