[postgis-devel] github action badges broken ?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 31 11:23:59 PDT 2023
OK, so getting a badge from the UI, the path is slightly different now…
https://github.com/postgis/postgis/actions/workflows/ci.yml/badge.svg?branch=master
> On Oct 31, 2023, at 11:19 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Oct 31, 2023 at 10:54:51AM -0400, Regina Obe via postgis-devel wrote:
>> It's weird that 3.2 is okay, maybe I have that wrong. Anyway I'll change on
>> all the locations
> The new locations are still broken:
> All green here: https://git.osgeo.org/gitea/postgis/postgis
> All green here: https://trac.osgeo.org/postgis/wiki
> But build is failing: https://github.com/postgis/postgis/actions?query=branch%3Amaster
> I would boycott GitHub as a whole as being defective-by-design (as
> non-free), anyway if any of you feels like discussing with the
> platform owners about the bug, here's the documentation stating we
> were using the right syntax for the badge:
> https://docs.github.com/en/actions/monitoring-and-troubleshooting-workflows/adding-a-workflow-status-badge#using-the-branch-parameter
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20231031/02d85ce5/attachment.htm>
