I probably should've used a different subject, as I don't really know if this is the same issue as #3952... On Fri, Aug 09, 2024 at 02:59:59PM -0500, Justin Pryzby wrote: > I hit this error and found a pre-existing bug report, but it's from 7 > years ago, and marked as closed. > https://trac.osgeo.org/postgis/ticket/3952
