cannot start commands during a parallel operation
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 9 13:19:22 PDT 2024
Where’s the PostGIS content to this? The stack trace doesn’t hit and PostGIS code, and the SQL doesn’t call any PostGIS functions…?
P
> On Aug 9, 2024, at 1:01 PM, Justin Pryzby <pryzby at telsasoft.com> wrote:
> I probably should've used a different subject, as I don't really know if
> this is the same issue as #3952...
> On Fri, Aug 09, 2024 at 02:59:59PM -0500, Justin Pryzby wrote:
>> I hit this error and found a pre-existing bug report, but it's from 7
>> years ago, and marked as closed.
>> https://trac.osgeo.org/postgis/ticket/3952
