cannot start commands during a parallel operation
Justin Pryzby
pryzby at telsasoft.com
Fri Aug 9 13:40:43 PDT 2024
On Fri, Aug 09, 2024 at 01:19:22PM -0700, Paul Ramsey wrote:
> Where’s the PostGIS content to this? The stack trace doesn’t hit and PostGIS code, and the SQL doesn’t call any PostGIS functions…?
Our get_x() calls postgis st_x().
ts=# \sf st_x
CREATE OR REPLACE FUNCTION public.st_x(geometry)
RETURNS double precision
LANGUAGE c
IMMUTABLE PARALLEL SAFE STRICT
AS '$libdir/postgis-3', $function$LWGEOM_x_point$function$
ts=# begin; SET parallel_tuple_cost=0; SET parallel_setup_cost=0; CREATE TABLE rpt AS SELECT get_x(site_id, site_alias) FROM sites; rollback;
ts=# \errverbose
ERROR: XX000: cannot start commands during a parallel operation
CONTEXT: SQL statement "select st_x(site_geo) AS x from sites where site_id = s_id"
PL/pgSQL function get_x(integer,integer) line 7 at SQL statement
