cannot start commands during a parallel operation
Paul Ramsey
pramsey at cleverelephant.ca
Fri Aug 9 13:43:22 PDT 2024
> On Aug 9, 2024, at 1:40 PM, Justin Pryzby <pryzby at telsasoft.com> wrote:
> On Fri, Aug 09, 2024 at 01:19:22PM -0700, Paul Ramsey wrote:
>> Where’s the PostGIS content to this? The stack trace doesn’t hit and PostGIS code, and the SQL doesn’t call any PostGIS functions…?
> Our get_x() calls postgis st_x().
And get_x() also does a transform along the way? Crazy that st_x() could cause any problems, it’s so simple.
P
> ts=# \sf st_x
> CREATE OR REPLACE FUNCTION public.st_x(geometry)
> RETURNS double precision
> LANGUAGE c
> IMMUTABLE PARALLEL SAFE STRICT
> AS '$libdir/postgis-3', $function$LWGEOM_x_point$function$
> ts=# begin; SET parallel_tuple_cost=0; SET parallel_setup_cost=0; CREATE TABLE rpt AS SELECT get_x(site_id, site_alias) FROM sites; rollback;
> ts=# \errverbose
> ERROR: XX000: cannot start commands during a parallel operation
> CONTEXT: SQL statement "select st_x(site_geo) AS x from sites where site_id = s_id"
> PL/pgSQL function get_x(integer,integer) line 7 at SQL statement
> LOCATION: CommandCounterIncrement, xact.c:1094
