PostGIS 3.5.0alpha1 released supports PG17
Paul Norman penorman at mac.com
Fri Jul 5 13:50:31 PDT 2024
On 2024-07-04 10:27 p.m., Sebastiaan Couwenberg wrote:
> On 7/5/24 7:03 AM, Regina Obe wrote:
>> To take advantage of all SFCGAL features, SFCGAL 1.5.0+ is needed.
> Note that SFCGAL won't support CGAL 6 any time soon [0], so SFCGAL
> support was disabled in the Debian package.
> Loïc Bartoletti mentioned that "Time, Money and/or Contributions" are
> needed to make SFCGAL work with CGAL 6. If SFCGAL support in PostGIS
> is considered important enough you should consider contributing to the
> CGAL 6 support in SFCAL.
They also said that SFCGAL 1.x will stick with CGAL 5, so there won't be
any compatibility until SFCGAL 2.0
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240705/390f2ef0/attachment.htm>
