Postgres OIDs and box2d, box2df, box3d, and gidx: differences and usage?
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jun 7 11:36:41 PDT 2024
On Fri, Jun 7, 2024 at 1:49 AM Tom Payne <twpayne at gmail.com> wrote:
> obstacledb=# SELECT typname, oid FROM pg_type WHERE typname IN ('box2d', 'box2df', 'box3d', 'gidx');
> typname | oid
> box3d | 5248539
> box2d | 5248543
> box2df | 5248547
> gidx | 5248551
> (4 rows)
Oh, and you probably already know this, but just for completeness: the
Oid numbers of the PostGIS types will VARY between databases, because
they are assigned at run-time by the PostgreSQL server. So the Oid you
have for geometry will not be the same as the one I have.
ATB,
P
