PG_Sphere
Gandalf the Gray pjduplooy.gis at gmail.com
Wed Oct 9 06:13:24 PDT 2024
Hi Regina.
Would it be possible to send me the Mingw build, or to guide me through the
build process, as I have MingW setup for Mame.
On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
wrote:
> Thank you Regina!
> On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us> wrote:
>> I’m troubleshooting why the PG17 ones I built (and that regressed fine
>> under Mingw) didn’t seem to install under PG17 VC++ build.
>> In all cases before, if I was able to get things to compile under MingW
>> they work fine in VC++ builds.
>> Once I figure that out (whether it’s my fault or something in the
>> pgsphere code), I’ll deploy those binaries.
>> BTW once they tag the 1.5.2 (which has the fix to build under mingw64
>> https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to
>> include it in the PostGIS windows bundles.
>> Thanks,
>> Regina
>> *From:* Gandalf the Gray <pjduplooy.gis at gmail.com>
>> *Sent:* Tuesday, October 8, 2024 6:42 AM
>> *To:* postgis-devel at lists.osgeo.org
>> *Subject:* PG_Sphere
>> Hi Regina.
>> Thanks a million for PG_Sphere binaries for Windows!!.
>> Any chance of a PG 17 version?
>> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241009/3c0346ab/attachment.htm>
