PG_Sphere
Regina Obe lr at pcorp.us
Wed Oct 9 06:46:23 PDT 2024
I’ve put the binaries I built here:
https://winnie.postgis.net/download/windows/pg17/buildbot/extras/
As far as compiling under mingw, there isn’t anything special I had to do aside from my usual specifying the postgresql version path.
So instructions they have assuming you’ve already installed autoconf, gcc++ etc should be sufficient.
export OS_BUILD=64
export PROJECTS=/projects
export GCC_TYPE=
export PG_VER=17
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
make USE_HEALPIX=0
make USE_HEALPIX=0 install
make installcheck USE_HEALPIX=0
I haven’t tried compiling with HEALPIX since that itself when I tried had additional dependencies to compile which I hadn’t gone thru to investigate.
Let me know if you need further help like setting up your tool chain.
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Wednesday, October 9, 2024 9:13 AM
To: Regina Obe <lr at pcorp.us>; postgis-devel at lists.osgeo.org
Subject: Re: PG_Sphere
Hi Regina.
Would it be possible to send me the Mingw build, or to guide me through the build process, as I have MingW setup for Mame.
On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Thank you Regina!
On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’m troubleshooting why the PG17 ones I built (and that regressed fine under Mingw) didn’t seem to install under PG17 VC++ build.
In all cases before, if I was able to get things to compile under MingW they work fine in VC++ builds.
Once I figure that out (whether it’s my fault or something in the pgsphere code), I’ll deploy those binaries.
BTW once they tag the 1.5.2 (which has the fix to build under mingw64  https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to include it in the PostGIS windows bundles.
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> >
Sent: Tuesday, October 8, 2024 6:42 AM
To: postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Subject: PG_Sphere
Hi Regina.
Thanks a million for PG_Sphere binaries for Windows!!.
Any chance of a PG 17 version?
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241009/e4620073/attachment.htm>
