PG_Sphere
Regina Obe
lr at pcorp.us
Wed Oct 9 08:36:13 PDT 2024
That’s what I was running into. But that looks to be your PostgreSQL windows install.
Works fine under my mingw64 postgresql built.
No clue at the moment why 17 doesn’t work but the others work fine.
I was going to take a deeper look later this week.
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Wednesday, October 9, 2024 11:04 AM
To: Regina Obe <lr at pcorp.us>; postgis-devel at lists.osgeo.org
Subject: Re: PG_Sphere
Hi Regina
I could not load PG_Sphere.
I have extracted the archive into my PG folder, and restarted PG. Upon create extension, I get "could not load library C:/Program Files/PostgreSQL/17/lib/pg_sphere.dll:; The specified procedure could not be found."
Any clue?
On Wed, Oct 9, 2024 at 3:50 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Thanks Regina.
Appreciate it!
On Wed, Oct 9, 2024 at 3:46 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’ve put the binaries I built here:
https://winnie.postgis.net/download/windows/pg17/buildbot/extras/
As far as compiling under mingw, there isn’t anything special I had to do aside from my usual specifying the postgresql version path.
So instructions they have assuming you’ve already installed autoconf, gcc++ etc should be sufficient.
export OS_BUILD=64
export PROJECTS=/projects
export GCC_TYPE=
export PG_VER=17
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
make USE_HEALPIX=0
make USE_HEALPIX=0 install
make installcheck USE_HEALPIX=0
I haven’t tried compiling with HEALPIX since that itself when I tried had additional dependencies to compile which I hadn’t gone thru to investigate.
Let me know if you need further help like setting up your tool chain.
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> >
Sent: Wednesday, October 9, 2024 9:13 AM
To: Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> >; postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Hi Regina.
Would it be possible to send me the Mingw build, or to guide me through the build process, as I have MingW setup for Mame.
On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Thank you Regina!
On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’m troubleshooting why the PG17 ones I built (and that regressed fine under Mingw) didn’t seem to install under PG17 VC++ build.
In all cases before, if I was able to get things to compile under MingW they work fine in VC++ builds.
Once I figure that out (whether it’s my fault or something in the pgsphere code), I’ll deploy those binaries.
BTW once they tag the 1.5.2 (which has the fix to build under mingw64 https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to include it in the PostGIS windows bundles.
Thanks,
Regina
Sent: Tuesday, October 8, 2024 6:42 AM
To: postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Subject: PG_Sphere
Hi Regina.
Thanks a million for PG_Sphere binaries for Windows!!.
Any chance of a PG 17 version?
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241009/e3d3dd7a/attachment-0001.htm>
