PG_Sphere
Gandalf the Gray
pjduplooy.gis at gmail.com
Thu Oct 10 23:48:12 PDT 2024
Hi Regina.
Any progress with this issue?
On Wed, Oct 9, 2024 at 5:36 PM Regina Obe <lr at pcorp.us> wrote:
> That’s what I was running into. But that looks to be your PostgreSQL
> windows install.
> Works fine under my mingw64 postgresql built.
> No clue at the moment why 17 doesn’t work but the others work fine.
> I was going to take a deeper look later this week.
> Thanks,
> Regina
> *From:* Gandalf the Gray <pjduplooy.gis at gmail.com>
> *Sent:* Wednesday, October 9, 2024 11:04 AM
> *To:* Regina Obe <lr at pcorp.us>; postgis-devel at lists.osgeo.org
> *Subject:* Re: PG_Sphere
> Hi Regina
> I could not load PG_Sphere.
> I have extracted the archive into my PG folder, and restarted PG. Upon
> create extension, I get "could not load library C:/Program
> Files/PostgreSQL/17/lib/pg_sphere.dll:; The specified procedure could not
> be found."
> Any clue?
> On Wed, Oct 9, 2024 at 3:50 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
> wrote:
> Thanks Regina.
> Appreciate it!
> On Wed, Oct 9, 2024 at 3:46 PM Regina Obe <lr at pcorp.us> wrote:
> I’ve put the binaries I built here:
> https://winnie.postgis.net/download/windows/pg17/buildbot/extras/
> As far as compiling under mingw, there isn’t anything special I had to do
> aside from my usual specifying the postgresql version path.
> So instructions they have assuming you’ve already installed autoconf,
> gcc++ etc should be sufficient.
> export OS_BUILD=64
> export PROJECTS=/projects
> export GCC_TYPE=
> export PG_VER=17
> export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
> export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
> make USE_HEALPIX=0
> make USE_HEALPIX=0 install
> make installcheck USE_HEALPIX=0
> I haven’t tried compiling with HEALPIX since that itself when I tried had
> additional dependencies to compile which I hadn’t gone thru to investigate.
> Let me know if you need further help like setting up your tool chain.
> Thanks,
> Regina
> *Sent:* Wednesday, October 9, 2024 9:13 AM
> Hi Regina.
> Would it be possible to send me the Mingw build, or to guide me through
> the build process, as I have MingW setup for Mame.
> On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
> wrote:
> Thank you Regina!
> On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us> wrote:
> I’m troubleshooting why the PG17 ones I built (and that regressed fine
> under Mingw) didn’t seem to install under PG17 VC++ build.
> In all cases before, if I was able to get things to compile under MingW
> they work fine in VC++ builds.
> Once I figure that out (whether it’s my fault or something in the pgsphere
> code), I’ll deploy those binaries.
> BTW once they tag the 1.5.2 (which has the fix to build under mingw64
> https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to
> include it in the PostGIS windows bundles.
> Thanks,
> Regina
> *Sent:* Tuesday, October 8, 2024 6:42 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* PG_Sphere
> Hi Regina.
> Thanks a million for PG_Sphere binaries for Windows!!.
> Any chance of a PG 17 version?
> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241011/f8c1f9bf/attachment.htm>
