PG_Sphere
Regina Obe lr at pcorp.us
Sun Oct 13 22:46:21 PDT 2024
Pieter,
I’ve made a lot of progress.  I isolated the offending line and remarked it out https://github.com/postgrespro/pgsphere/blob/master/src/output.c#L163  for now as discussed in -  https://github.com/postgrespro/pgsphere/issues/130  Didn’t want to introduce a windows only function to compensate unless I have to.
It’s not ideal but at least you can do CREATE EXTENSION and some other things.  You can find the binaries in -  https://winnie.postgis.net/download/windows/pg17/buildbot/extras/
I’ll let you know once I have a build that regresses cleanly.
Just for reference this is the regression results:
ok 1         - init                                      127 ms
ok 2         - version                                    37 ms
ok 3         - tables                                    866 ms
ok 4         - points                                     49 ms
ok 5         - euler                                      43 ms
ok 6         - circle                                     49 ms
ok 7         - line                                       41 ms
ok 8         - ellipse                                    58 ms
ok 9         - poly                                      104 ms
ok 10        - path                                       52 ms
ok 11        - box                                        76 ms
ok 12        - index                                     150 ms
ok 13        - contains_ops                               78 ms
ok 14        - contains_ops_compat                        80 ms
not ok 15    - bounding_box_gist                        1396 ms
# (test process exited with exit code 2)
not ok 16    - gnomo                                      35 ms
not ok 17    - epochprop                                  34 ms
not ok 18    - contains                                   34 ms
not ok 19    - overlaps                                   33 ms
not ok 20    - spoint_brin                              1247 ms
not ok 21    - sbox_brin                                  33 ms
not ok 22    - selectivity                                33 ms
not ok 23    - knn                                      1699 ms
not ok 24    - output_precision                           42 ms
not ok 25    - gist_support                               41 ms
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Friday, October 11, 2024 2:48 AM
To: Regina Obe <lr at pcorp.us>; postgis-devel at lists.osgeo.org
Subject: Re: PG_Sphere
Hi Regina.
Any progress with this issue?
On Wed, Oct 9, 2024 at 5:36 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
That’s what I was running into.  But that looks to be your PostgreSQL windows install.
Works fine under my mingw64 postgresql built.
No clue at the moment why 17 doesn’t work but the others work fine.
I was going to take a deeper look later this week.
Thanks,
Regina
From: Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> >
Sent: Wednesday, October 9, 2024 11:04 AM
To: Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> >; postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Hi Regina
I could not load PG_Sphere.
I have extracted the archive into my PG folder, and restarted PG.  Upon create extension, I get "could not load library C:/Program Files/PostgreSQL/17/lib/pg_sphere.dll:; The specified procedure could not be found."
Any clue?
On Wed, Oct 9, 2024 at 3:50 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Thanks Regina.
Appreciate it!
On Wed, Oct 9, 2024 at 3:46 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’ve put the binaries I built here:
As far as compiling under mingw, there isn’t anything special I had to do aside from my usual specifying the postgresql version path.
So instructions they have assuming you’ve already installed autoconf, gcc++ etc should be sufficient.
export OS_BUILD=64
export PROJECTS=/projects
export GCC_TYPE=
export PG_VER=17
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
make USE_HEALPIX=0
make USE_HEALPIX=0 install
make installcheck USE_HEALPIX=0
I haven’t tried compiling with HEALPIX since that itself when I tried had additional dependencies to compile which I hadn’t gone thru to investigate.
Let me know if you need further help like setting up your tool chain.
Thanks,
Regina
Sent: Wednesday, October 9, 2024 9:13 AM
Hi Regina.
Would it be possible to send me the Mingw build, or to guide me through the build process, as I have MingW setup for Mame.
On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com> > wrote:
Thank you Regina!
On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’m troubleshooting why the PG17 ones I built (and that regressed fine under Mingw) didn’t seem to install under PG17 VC++ build.
In all cases before, if I was able to get things to compile under MingW they work fine in VC++ builds.
Once I figure that out (whether it’s my fault or something in the pgsphere code), I’ll deploy those binaries.
BTW once they tag the 1.5.2 (which has the fix to build under mingw64  https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to include it in the PostGIS windows bundles.
Thanks,
Regina
Sent: Tuesday, October 8, 2024 6:42 AM
To: postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Subject: PG_Sphere
Hi Regina.
Thanks a million for PG_Sphere binaries for Windows!!.
Any chance of a PG 17 version?
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241014/46be06df/attachment-0001.htm>
