PG_Sphere
Gandalf the Gray pjduplooy.gis at gmail.com
Sun Oct 13 22:59:16 PDT 2024
Thanks Regina.
I appreciate it!!
Pieter
On Mon, Oct 14, 2024 at 7:46 AM Regina Obe <lr at pcorp.us> wrote:
> Pieter,
> I’ve made a lot of progress.  I isolated the offending line and remarked
> it out
> https://github.com/postgrespro/pgsphere/blob/master/src/output.c#L163
> for now as discussed in -
> https://github.com/postgrespro/pgsphere/issues/130  Didn’t want to
> introduce a windows only function to compensate unless I have to.
> It’s not ideal but at least you can do CREATE EXTENSION and some other
> things.  You can find the binaries in -
> https://winnie.postgis.net/download/windows/pg17/buildbot/extras/
> I’ll let you know once I have a build that regresses cleanly.
> Just for reference this is the regression results:
> ok 1         - init                                      127 ms
> ok 2         - version                                    37 ms
> ok 3         - tables                                    866 ms
> ok 4         - points                                     49 ms
> ok 5         - euler                                      43 ms
> ok 6         - circle                                     49 ms
> ok 7         - line                                       41 ms
> ok 8         - ellipse                                    58 ms
> ok 9         - poly                                      104 ms
> ok 10        - path                                       52 ms
> ok 11        - box                                        76 ms
> ok 12        - index                                     150 ms
> ok 13        - contains_ops                               78 ms
> ok 14        - contains_ops_compat                        80 ms
> not ok 15    - bounding_box_gist                        1396 ms
> # (test process exited with exit code 2)
> not ok 16    - gnomo                                      35 ms
> not ok 17    - epochprop                                  34 ms
> not ok 18    - contains                                   34 ms
> not ok 19    - overlaps                                   33 ms
> not ok 20    - spoint_brin                              1247 ms
> not ok 21    - sbox_brin                                  33 ms
> not ok 22    - selectivity                                33 ms
> not ok 23    - knn                                      1699 ms
> not ok 24    - output_precision                           42 ms
> not ok 25    - gist_support                               41 ms
> Thanks,
> Regina
> *From:* Gandalf the Gray <pjduplooy.gis at gmail.com>
> *Sent:* Friday, October 11, 2024 2:48 AM
> *To:* Regina Obe <lr at pcorp.us>; postgis-devel at lists.osgeo.org
> *Subject:* Re: PG_Sphere
> Hi Regina.
> Any progress with this issue?
> On Wed, Oct 9, 2024 at 5:36 PM Regina Obe <lr at pcorp.us> wrote:
> That’s what I was running into.  But that looks to be your PostgreSQL
> windows install.
> Works fine under my mingw64 postgresql built.
> No clue at the moment why 17 doesn’t work but the others work fine.
> I was going to take a deeper look later this week.
> Thanks,
> Regina
> *Sent:* Wednesday, October 9, 2024 11:04 AM
> Hi Regina
> I could not load PG_Sphere.
> I have extracted the archive into my PG folder, and restarted PG.  Upon
> create extension, I get "could not load library C:/Program
> Files/PostgreSQL/17/lib/pg_sphere.dll:; The specified procedure could not
> be found."
> Any clue?
> On Wed, Oct 9, 2024 at 3:50 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
> wrote:
> Thanks Regina.
> Appreciate it!
> On Wed, Oct 9, 2024 at 3:46 PM Regina Obe <lr at pcorp.us> wrote:
> I’ve put the binaries I built here:
> As far as compiling under mingw, there isn’t anything special I had to do
> aside from my usual specifying the postgresql version path.
> So instructions they have assuming you’ve already installed autoconf,
> gcc++ etc should be sufficient.
> export OS_BUILD=64
> export PROJECTS=/projects
> export GCC_TYPE=
> export PG_VER=17
> export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
> export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
> make USE_HEALPIX=0
> make USE_HEALPIX=0 install
> make installcheck USE_HEALPIX=0
> I haven’t tried compiling with HEALPIX since that itself when I tried had
> additional dependencies to compile which I hadn’t gone thru to investigate.
> Let me know if you need further help like setting up your tool chain.
> Thanks,
> Regina
> *Sent:* Wednesday, October 9, 2024 9:13 AM
> Hi Regina.
> Would it be possible to send me the Mingw build, or to guide me through
> the build process, as I have MingW setup for Mame.
> On Tue, Oct 8, 2024 at 5:00 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
> wrote:
> Thank you Regina!
> On Tue, Oct 8, 2024 at 3:59 PM Regina Obe <lr at pcorp.us> wrote:
> I’m troubleshooting why the PG17 ones I built (and that regressed fine
> under Mingw) didn’t seem to install under PG17 VC++ build.
> In all cases before, if I was able to get things to compile under MingW
> they work fine in VC++ builds.
> Once I figure that out (whether it’s my fault or something in the pgsphere
> code), I’ll deploy those binaries.
> BTW once they tag the 1.5.2 (which has the fix to build under mingw64
> https://github.com/postgrespro/pgsphere/pull/123 ), I’m planning to
> include it in the PostGIS windows bundles.
> Thanks,
> Regina
> *Sent:* Tuesday, October 8, 2024 6:42 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* PG_Sphere
> Hi Regina.
> Thanks a million for PG_Sphere binaries for Windows!!.
> Any chance of a PG 17 version?
> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20241014/4eec4a8a/attachment-0001.htm>
