PostGIS 3.4.3 Released
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 5 06:24:55 PDT 2024
No, it was specific to area.
P
> On Sep 4, 2024, at 11:59 PM, Marco Boeringa <marco at boeringa.demon.nl> wrote:
> Aren't ST_Perimeter() and ST_Length() potentially affected by:
> - #5671, Bug in ST_Area function with use_spheroid=false
> (Paul Ramsey, Regina Obe)
> They have the 'use_spheroid' input option as well.
> Marco
> Op 4-9-2024 om 21:58 schreef Paul Ramsey:
>> http://postgis.net/2024/09/PostGIS-3.4.3/
>> The PostGIS team is pleased to release PostGIS 3.4.3! This release is
>> a maintenance and bug fix release.
>> Issues Closed:
>> - #5766, Always report invalid non-null MBR of universal face (Sandro Santilli)
>> - #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
>> - #5698, Fix robustness issue splitting line by vertex very close to endpoints,
>> affecting topology population functions (Sandro Santilli)
>> - #5649, ST_Value should return NULL on missing band (Paul Ramsey)
>> - #5677, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)
>> - #5679, Remove spurious COMMIT statements from sfcgal script
>> (Sandro Santilli, Loïc Bartoletti)
>> - #5680, Fix populate_topology_layer with standard_conforming_strings
>> set to off (Sandro Santilli)
>> - #5589, ST_3DDistance error for shared first point (Paul Ramsey)
>> - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
>> - #5666, Build reproducibility: timestamps
>> in extension upgrade SQL scripts (James Addison)
>> - #5687, Don't rely on search_path to determine postgis schema
>> Fix for PG17 security change (Regina Obe)
>> - #5695, [address_standardizer_data_us] standardize_address
>> incorrect handling of directionals (Regina Obe)
>> - #5653, Do not simplify away points when linestring doubles back on
>> itself (Paul Ramsey)
>> - #5720, Correctly mangle special column names in shp2pgsql (Paul Ramsey)
>> - #5734, Estimate geography extent more correctly (Paul Ramsey)
>> - #5752, ST_ClosestPoint(geography) error (Paul Ramsey)
>> - #5740, ST_DistanceSpheroid(geometry) incorrectly handles polygons
>> (Paul Ramsey)
>> - #5765, Handle nearly co-linear edges with slightly less slop (Paul Ramsey)
>> - #5745, St_AsLatLonText rounding errors (Paul Ramsey)
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240905/31c4d83c/attachment.htm>
