PostGIS 3.4.3 Released
Marco Boeringa
marco at boeringa.demon.nl
Wed Sep 4 23:59:23 PDT 2024
Aren't ST_Perimeter() and ST_Length() potentially affected by:
- #5671, Bug in ST_Area function with use_spheroid=false (Paul Ramsey,
Regina Obe)
They have the 'use_spheroid' input option as well. Marco
Op 4-9-2024 om 21:58 schreef Paul Ramsey:
> http://postgis.net/2024/09/PostGIS-3.4.3/
> The PostGIS team is pleased to release PostGIS 3.4.3! This release is
> a maintenance and bug fix release.
> Issues Closed:
> - #5766, Always report invalid non-null MBR of universal face (Sandro Santilli)
> - #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
> - #5698, Fix robustness issue splitting line by vertex very close to endpoints,
> affecting topology population functions (Sandro Santilli)
> - #5649, ST_Value should return NULL on missing band (Paul Ramsey)
> - #5677, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)
> - #5679, Remove spurious COMMIT statements from sfcgal script
> (Sandro Santilli, Loïc Bartoletti)
> - #5680, Fix populate_topology_layer with standard_conforming_strings
> set to off (Sandro Santilli)
> - #5589, ST_3DDistance error for shared first point (Paul Ramsey)
> - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
> - #5666, Build reproducibility: timestamps
> in extension upgrade SQL scripts (James Addison)
> (Paul Ramsey, Regina Obe)
> - #5687, Don't rely on search_path to determine postgis schema
> Fix for PG17 security change (Regina Obe)
> - #5695, [address_standardizer_data_us] standardize_address
> incorrect handling of directionals (Regina Obe)
> - #5653, Do not simplify away points when linestring doubles back on
> itself (Paul Ramsey)
> - #5720, Correctly mangle special column names in shp2pgsql (Paul Ramsey)
> - #5734, Estimate geography extent more correctly (Paul Ramsey)
> - #5752, ST_ClosestPoint(geography) error (Paul Ramsey)
> - #5740, ST_DistanceSpheroid(geometry) incorrectly handles polygons
> (Paul Ramsey)
> - #5765, Handle nearly co-linear edges with slightly less slop (Paul Ramsey)
> - #5745, St_AsLatLonText rounding errors (Paul Ramsey)
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240905/907f3774/attachment.htm>
